SSI SPI接口
SSI是一个全双工同步串行接口,可以连接到多种外部模拟-数字(A/D)转换器、音频和电信编解码器以及其他使用串行传输数据的协议。X1600支持SSI摩托罗拉的串行外设接口(SPI)协议。
  • GPIO功能描述
Name I/O Description
SSI_CLK Output Serialbit-rateclock
SSI_CE0 Output Firstslaveselectenable
SSI_DT Output Transmitdata(serialdataout)
SSI_DR Input Receivedata(serialdatain)
  • GPIO接口
SSI0 PA28-31 FUNCTION0
SSI0 PB02 FUNCTION2
SSI0 PB12-14 PB16-17 FUNCTION1
module_drivers/drivers/spi
├── ingenic_spi.c
├── ingenic_spi.h
├── ingenic_slv.c
├── ingenic_slv.h
SPI控制器描述:
spi0: spi0@0x10043000 {
 compatible = "ingenic,x1600- spi";
 reg = <0x10043000 0x1000>;
 interrupts = <IRQ_SSI0>;
 dmas = <&pdma INGENIC_DMA_TYPE(INGENIC_DMA_REQ_SSI0_TX)>,
 <&pdma INGENIC_DMA_TYPE(INGENIC_DMA_REQ_SSI0_RX)>;
 dma-names = "tx", "rx";
 #address-cells = <1>;
 #size-cells = <0>;
 status = "disabled";
设备树默认关闭SPI控制器设备。
用户可根据实际需求打开SPI控制器设备,例如:
&spi0 {
 status = "disable";
 pinctrl-names = "default";
 pinctrl-0 = <&spi0_pb>;
 spi-max-frequency = <54000000>;
 num-cs = <2>;
 /* cs-gpios = <0>, <0>; */
 /* cs-gpios = <&gpb 17 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>, <&gpb 16 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>; */
 ingenic,chnl = <0>;
 ingenic,allow_cs_same = <1>;
 ingenic,bus_num = <0>;
 ingenic,has_dma_support = <0>;
 ingenic,spi-src-clk = <1>;/*0.ext; 1.ssi*/
 /* Add SPI interface device */
 spidev: spidev@0 {
 compatible = "rohm,dh2228fv";
 reg = <0>;
 spi-max-frequency = <10000000>;
其中部分属性含义如下:
spi-max-frequency spi控制器最大工作频率
ingenic,chnl spi编号
ingenic,has_dma_support 是否使用dma,1表示使用dma
ingenic,spi-src-clk 设备时钟源的选择
num-cs 控制器有几根片选pin
用gpio模拟spi协议
为满足一些特殊的协议要求,也可以采用基于bitbang的gpio模拟spi功能.
将如下spi-gpio节点,添加设备树根节点下:
在kernel4.4.94中设备树添加方法如下:
 spi_gpio {
 status = "okay";
 compatible = "spi-gpio";
 #size-cells = <0>;
 gpio-sck = <&gpd 2 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 gpio-miso = <&gpd 4 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 gpio-mosi = <&gpd 5 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 cs-gpios = <&gpd 3 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 num-chipselects = <1>;
 /* clients */
 spidev1: spidev1@0 {
 status = "disable";
 reg = <0>;
 spi-max-frequency = <500000>;
在kernel5.10中设备树添加方法如下:
 spi_gpio {
 status = "okay";
 #size-cells = <0>;
 sck-gpios = <&gpd 2 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
 miso-gpios = <&gpd 4 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
 mosi-gpios = <&gpd 5 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
 cs-gpios = <&gpd 3 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
 /* clients */
 status = "disable";
 reg = <0>;
根据“Documentation/devicetree/bindings/spi/spi-gpio.yaml”文件中的描述,kernel5.10中已经废弃原有的属性“gpio-sck”、“gpio-miso”和“gpio-mosi”,但实际kernel5.10内核依然保留了对原有属性的解析,建议采用新的devicetree属性。
内核配置INGENIC_SPI,配置说明如下:
Symbol: INGENIC_SPI [=n]
Type : tristate
Prompt: Ingenic SPI Controller
(1) -> [SPI] Master/Slave Drivers
 Defined at module_drivers/drivers/spi/Kconfig:1
 Depends on: MACH_XBURST [=y] || MACH_XBURST2 [=n]
 Selects: SPI_BITBANG [=n]
内核默认关闭SPI控制器驱动
用户可根据实际需求打开SPI控制器编译,配置界面如下:
用gpio模拟spi协议
Device Drivers --->
 [*] SPI support --->
 -*- Utilities for Bitbanging SPI masters
 <*> GPIO-based bitbanging SPI Master
 <*> User mode SPI device driver support /*向用户提供设备设备节点*/
< > Ingenic SPI Controller /*去掉ingenic ssi控制器配置*/
驱动加载成功log
[ 0.298196] INGENIC SSI Controller for SPI channel 0 driver register
生成设备节点:
/dev/spidev0.0
当使用gpio模拟spi协议时,产生设备节点spidev%d.%d*,例如:
/dev/spidev32766.0
内核的 spi 驱动程序是基于 spi 子系统架构编写的
应用程序可以使用spi_demo进行测试
  1. 可以在内核空间通过spi驱动操作 spi 接口
  2. 可以在用户空间通过 spi_ioc_transfer 操作 spi 接口
测试spi读写
源码位置
kernel4.4.94应用程序在如下位置:
Documentation/spi/spidev_test.c
kernel5.10程序在如下位置:
tools/spi/spidev_test.c
测试方法
1.将SSI0_DT和SSI0_DR引脚短接
\# ./spi_test --help
./spi_test: unrecognized option '--help'
Usage: ./spi_test [-DsbdlHOLC3]
 -D --device device to use (default /dev/spidev1.1)
 -s --speed max speed (Hz)
 -d --delay delay (usec)
 -b --bpw bits per word
 -l --loop loopback
 -H --cpha clock phase
 -O --cpol clock polarity
 -L --lsb least significant bit first
 -C --cs-high chip select active high
 -3 --3wire SI/SO signals shared
 -v --verbose Verbose (show tx buffer)
 -p Send data (e.g. "1234\xde\xad")
 -N --no-cs no chip select
 -R --ready slave pulls low to pause
 -2 --dual dual transfer
 -4 --quad quad transfer
  1. spidev_test -D /dev/spidev0.0
测试结果
\# ./spi_test -D /dev/spidev0.0
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D | ......@......................�.
测试spi nor flash
针对spi接口的nor flash,内核已经有对应驱动支持,如果想使用只需要正确配置即可。
kernel4.4.94版本操作
设备树位置:
module_drivers/dts-stage/x1600/halley6_v10.dts
需要在spi_gpio节点内添加nor flash的节点:
spi_gpio {
 status = "okay";
 #size-cells = <0>;
 /* clients */
 m25p80 {
 compatible = "m25p80";
 reg = <0>;
 spi-max-frequency = <1000000>;
  1. 编译 drivers/spi/spi-gpio.c
位置:Device Drivers > SPI support
选中GPIO-based bitbanging SPI Master,如下图所示:
  1. 编译drivers/mtd/spi-nor/spi-nor.c
位置:Device Drivers > Memory Technology Device (MTD) support
选中SPI-NOR device support,如下图所示:
  1. 编译drivers/mtd/devices/m25p80.c
位置:Device Drivers > Memory Technology Device (MTD) support > Self-contained MTD device module_drivers/drivers
选中Support most SPI Flash chips (AT26DF, M25P, W25X, ...),如下图所示:
测试
  1. 确保nor flash硬件已经连接好;
  2. 在drivers/mtd/spi-nor/spi-nor.c中根据nor flash的型号,查找下表看是否有对应的型号支持,如果没有需要配置对应的参数:
static const struct flash_info spi_nor_ids[] = {
/* Atmel -- some are (confusingly) marketed as "DataFlash" */
{ "at25fs010", INFO(0x1f6601, 0, 32 * 1024, 4, SECT_4K) },
{ "at25fs040", INFO(0x1f6604, 0, 64 * 1024, 8, SECT_4K) },
{ "xm25qh128c", INFO(0x204018, 0, 4 * 1024, 4096, SECT_4K)},
/* GigaDevice */
{ "gd25q32", INFO(0xc84016, 0, 64 * 1024, 64, SECT_4K) },
{ "gd25q64", INFO(0xc84017, 0, 64 * 1024, 128, SECT_4K) },
{ "gd25q128", INFO(0xc84018, 0, 64 * 1024, 256, SECT_4K) },
  1. 重新编译kernel并烧录;
  2. 看到如下信息则表示添加成功:
[ 1.571673] m25p80 spi32766.0: xm25qh128c (16384 Kbytes)
这里示范的nor flash型号为xm25qh128c,大小为16MB,具体打印信息与spi-nor.c文件中struct flash_info spi_nor_ids[] 结构体中配置的参数相同;
  1. 进入到根文件系统后,可执行如下命令进一步确认,如果增加了一个新的mtd分区,则表示添加成功,这里mtd0为新添加的nor flash对应的分区
同时,在/dev目录下也会生成对应的设备节点,这里示范的为mtd0、mtd0ro、mtdblock0三个设备节点,其中mtd0和mtd0ro为字符设备节点,差别在于mtd0为可读写,mtd0ro只读,mtdblock0为块设备节点,可读写,如下图所示:
  1. 接下来可以使用诸如flash_erase、mtd_debug等命令对nor flash生成的字符设备节点mtd0进行读写,同时也可以对块设备节点mtdblock0进行格式化、挂载、文件系统读写等一系列操作,这里不再进行示范。
kernel5.10版本操作
设备树位置:
spi_gpio {
 status = "okay";
 #size-cells = <0>;
 /* clients */
 m25p80 {
 reg = <0>;
 spi-max-frequency = <1000>;
 #size-cells = <1>;
建议gpio引用中的gpio极性采用“GPIO_ACTIVE_HIGH”,不然会无法识别nor flash,导致无法注册mtd设备。
  1. 编译drivers/mtd/spi-nor/core.c
由于kernel5.10将kernel4.4.94中的spi-nor.c和m25p80.c文件合并成了core.c,所以kernel5.10中只用选择SPI-NOR device support即可。
测试
  2. 在drivers/mtd/spi-nor/路径下已经定义了大部分nor flash厂商的芯片信息,用户可根据实际所使用的nor flash类型,确认相应的nor flash信息中是否含有对应的芯片,目前包含的厂商信息有:
atmel.c esmt.c fujitsu.c intel.c
spansion.c winbond.c xmc.c catalyst.c
eon.c everspin.c gigadevice.c ssi.c
macronix.c micron-st.c sst.c xilinx.c
  1. 重新编译kernel并烧录;
  2. 看到如下信息则表示添加成功:
spi-nor spi1.0: found XM25QH128C, expected m25p80
spi-nor spi1.0: XM25QH128C (16384 Kbytes)
这里示范的nor flash型号为xm25qh128c,大小为16MB,具体打印信息与xmc.c文件中struct flash_info xmc_parts[] 结构体中配置的参数相同;
