DTRNG模块驱动接口
真随机数发生器,用于在加解密场景提供真随机数的功能。
module_drivers/drivers/char/hw_random/ingenic-rng.c
设备树描述:
dtrng: dtrng@0x10072000 {
compatible = "ingenic,dtrng";
reg = <0x10072000 0x100>;
interrupts = <IRQ_DTRNG>;
status = "disabled";
};设备树默认配置
默认编译会产生dtrng设备。
&dtrng {
};设备树自定义配置
如果客户需要关闭dtrng设备,可以将以上节点配置为disabled。
&dtrng {
};内核编译配置
内核配置HW_RANDOM_INGENIC,配置说明如下:
Symbol: HW_RANDOM_INGENIC [=y] Type : tristate Prompt: Ingenic HW Random Number Generator support Location: -> Device Drivers -> Character devices (1) -> Hardware Random Number Generator Core support (HW_RANDOM [=y]) Prompt: [RANDOM] Ingenic HW Random Number Generator support Location: -> Ingenic device-drivers Configurations (2) -> [RANDOM] drivers Defined at drivers/char/hw_random/Kconfig:384 Depends on: HW_RANDOM [=y] && MIPS [=y]
内核默认配置dtrng驱动:
客户可以根据实际情况,去掉该驱动的配置。
当驱动加载成功后,会生成/dev/hwrng, 用户可以根据此节点判断驱动是否成功加载。
可以通过以下应用程序,测试随机数。
#include<stdio.h>
#include<stdlib.h>
#include<linux/watchdog.h>
#include<sys/ioctl.h>
#include<sys/types.h>
#include<fcntl.h>
#include<unistd.h>
#include<errno.h>
int main(int argc, char *argv[])
int fd ,retval;
char buf[64] = {0};
int cmd = 0;
if (!argv[1])
printf("argv[1] is NULL \n");
exit(errno);
fd = open(argv[1],O_RDONLY);
if(fd < 0)
printf("open %s false\n",argv[1]);
exit(errno);
if(read(fd,buf,32) < 0)
printf(" read false\n");
else
printf("random_num register value %d\n",*(unsigned int *)buf);
close(fd);
return retval;
}测试结果
\# ./hwrng /dev/hwrng random_num register value 9363246 \# ./hwrng /dev/hwrng random_num register value 1329736129 \# ./hwrng /dev/hwrng random_num register value 567871915 \# ./hwrng /dev/hwrng random_num register value 966768232
