Audio音频子系统
AIC支持I2S或IIS协议,用于在处理器的系统内存(外部I2S编解码器)之间传输数字化音频。
  • 支持独立时钟、共享时钟
  • 支持i2s, left justified协议
  • 支持主、从模式
硬件说明
由于x1600的i2s和mac共用一组GPIO,所以在使用时只能选择使用录放音功能还是以太网功能,在硬件设计上也需要通过短接CON6来选择使用哪个功能,如果使用录放音功能需要短接CON6,如果使用以太网功能不需要短接CON6。
audio控制器源码位置:
module_drivers/sound/soc/ingenic/as-v1
板级源码位置:
module_drivers/sound/soc/ingenic/boards
外部codec源码位置:
module_drivers/sound/soc/ingenic/ecodec/
设备树所在位置
内核dts文件路径:
Audio控制器描述:
aic: aic@0x10079000 {
    compatible = "ingenic,x1600-aic";
    reg = <0x10079000 0x100>;
    interrupts = <IRQ_AUDIO>;
    dmas = <&pdma INGENIC_DMA_TYPE(INGENIC_DMA_REQ_ASOC_AIC_TX)>,
    <&pdma INGENIC_DMA_TYPE(INGENIC_DMA_REQ_ASOC_AIC_RX)>;
    dma-names = "tx", "rx";
    i2s: i2s {
        compatible = "ingenic,x1600-i2s";
        status = "ok";
    i2s_tloop: i2s_tloop {
        compatible = "ingenic,i2s-tloop";
        dmas=<&pdma INGENIC_DMA_TYPE(INGENIC_DMA_REQ_ASOC_AIC_LOOP)>;
        dma-names = "rx";
        status = "ok";
设备树默认编译不会产生audio设备,并在module_drivers/dts-stage/x1600/halley6_v20.dts或module_drivers/dts/x1600/halley6_v20.dts下配置:
&aic {
    status = "disable";
    pinctrl-names = "default";
    pinctrl-0 = <&aic_pb>;
dump_pcm_codec:dump_pcm_codec{
    compatible = "ingenic,pcm-dump-codec";
    status = "disable";
sound_halley6_ecdc {
    status = "disable";
    compatible = "ingenic,x1600-sound";
    ingenic,model = "halley6";
    ingenic,dai-link = "i2s-ecodec", "i2s-tloop";
    ingenic,stream = "i2s-ecodec", "i2s-tloop";
    ingenic,cpu-dai = <&i2s>, <&i2s_tloop>;
    ingenic,platform = <&aic>, <&i2s_tloop>;
    ingenic,codec = <&dump_pcm_codec>, <&dump_pcm_codec>;
    ingenic,codec-dai = "pcm-dump", "pcm-dump";
    ingenic,en3v3-gpios = <&gpb 30 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
用户可根据实际需求开启audio设备。
内核配置SND_ASOC_INGENIC,配置说明如下:
Symbol: SND_ASOC_INGENIC [=y]
Type : tristate
Prompt: [AUDIO] ASoC support for Ingenic
Defined at module_drivers/sound/soc/ingenic/Kconfig:1
Depends on: MACH_XBURST [=y] || MACH_XBURST2 [=n]
Selects: SND_SOC [=y] && SND [=y] && SOUND [=y]
内核默认配置audio驱动,配置界面如下:
Ingenic device-drivers Configurations --->
<*> [AUDIO] ASoC support for Ingenic --->
[ ] enable ingenic debug message
[ ] enable ingenic verbose debug message
[ ] enable dmic and amic sync
 Audio Version: (AudioSystem Version 1 For Ingenic SOCs) --->
 select aic clock mode (aic use independent clock mode) --->
 select audio mono channel (select audio mono channel right) --->
 select aic clock direction (aic as master mode) --->
 select aic protocol mode (aic use i2s protocol) --->
 Ingenic Board Type Select --->
 ingenic external codec Type select --->
用户可根据实际需求去掉该驱动的配置。
驱动加载成功后生成以下节点:
/dev/snd/controlC0
/dev/snd/pcmC0D0p
/dev/snd/pcmC0D0c
/dev/snd/pcmC0D1c
/dev/snd/timer
pcmC0D0p表示放音设备,pcmC0Dc表示录音设备。*
添加新的codec驱动
在需要添加新的codec驱动时,用户可以参考“module_drivers/sound/soc/ingenic/ecodec”下的驱动来编写自己的驱动代码,在使用的新的codec驱动代码时,需要修改dts的以下内容:
    status = "disable";
用户需要将“ingenic,codec”和“ingenic,codec-dai”中的内容进行修改。
录放音方法
arecord命令录音,aplay命令放音
# arecord -D hw:0,0 -c 2 -f S16_LE -r 16000 -d 5 baic0_16000-32-1.wav
# aplay -D hw:0,0 baic0_16000-32-1.wav
asound.conf介绍
asound.conf配置文件,是alsa-lib的默认配置文件,路径在 /etc/,可以用来配置alsa库的一些附加功能。这个文件不是alsa库运行时所必须的,没有它alsa库也可以正常运行。asound.conf允许对声卡或者设备进行更高级的控制,提供访问alsa-lib中的pcm插件方法,允许你做更多的复杂的控制,比如可以把声卡组合成一个或者多声卡访问多个I/O。
在ALSA中,PCM插件扩展了PCM设备的功能和特性。插件可以自动处理诸如:命名设备、采样率转换、通道间的采样复制、写入文件、为多个输入/输出连接声卡/设备(不同步采样)、使用多通道声卡/设备等工作。
    1. hw插件
此插件直接与ALSA内核驱动程序通信,它是一种没有任何转换的原始通信。
通过此插件可以对pcm设备进行重命名操作。
例如:
# arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: halley6 [halley6], device 0: i2s-ecodec dump_pcm_codec-0 []
 Subdevices: 1/1
 Subdevice #0: subdevice #0
card 0: halley6 [halley6], device 1: i2s-tloop dump_pcm_codec-1 []
 Subdevices: 1/1
# aplay -l
**** List of PLAYBACK Hardware Devices ****
 Subdevices: 1/1
在使用arecord或者aplay进行录放音时,在指定设备时一般使用“hw:0,0”这种方法指定录放音所使用的设备,使用起来不够直观,可以通过hw插件对设备定义别名。例如:
pcm.amic {
 type hw
 card 0
 device 0
此例子中将“hw:0,0”进行了重命名操作,在录放音时可以使用以下方式:
# arecord -D amic-c 2 -f S16_LE -r 16000 -d 5 baic0_16000-32-1.wav
# aplay -D amic baic0_16000-32-1.wav
    1. slave插件
从属插件可以直接用字符串指定,也可以在一个复合配置节点内输入定义。还可以指定一些限制(如静态速率或通道数)。
例如:
pcm_slave.slave_rate48000Hz {
 pcm "hw:0,0"
 rate 48000
pcm.rate48000Hz {
 type plug
 slave slave_rate48000Hz
或者
pcm.rate48000Hz {
 type plug
 slave {
 pcm "hw:0,0"
 rate 48000
上述例子可以理解为:定义了一个虚拟的pcm设备命名为rate48000Hz,该设备实际使用“hw:0,0”pcm设备且设定只支持48000Hz采样率。在使用rate48000Hz该pcm设备录放音时,硬件上仅支持48000采样率,也可以设置固定的格式位、宽通道数等。
    1. rate插件
该插件转换速率。输入和输出格式必须是线性的,常用于播放硬件不支持采样率数据位宽的音频文件。
例如:
pcm.rate_16000 {
 type rate
 slave {
pcm "hw:0,0"
 rate 16000
 format S8
该插件支持采样率和采样格式位宽的转换,不支持通道的转换。
    1. plug插件
该插件可根据要求转换通道,速率和格式,比rate插件多了通道转换的功能。
例如:
pcm.rate_48000 {
 type plug
 slave {
 pcm "hw:0,0"
 rate 16000
 format S8
 channels 1
    1. Soft Volume
此插件应用于软件音量的调整。
例如:
pcm.amic_record {
 type softvol
 slave {
 pcm "hw:0,0"
 control {
 name "amic volume"
 min_dB -51.0
 max_dB 30.0
在第一次使用 softvol 插件进行播放时才会生成对应的控件,即调音时需要先执行一次“arecord -D amic_record”(以上述定义为例),才可以通过amixer设置调整音量。
tloop用法
tloop即放音回采功能,该功能是将放音的数据直接进行回采,具体操作为:
首先需要正常的放音和录音,然后对放音的数据进行回采:
# aplay -D i2s_play 16000-16-1.wav &
# arecord -D i2s_record -f S16_LE -r 16000 - c 1 xxxxx.wav &
# arecord -D i2s_tloop -f S16_LE -r 16000 -c 1 xxxxx.wav &
注意事项:
1.正常录音和回采录音必须使用单声道
2.正常录音和回采录音必须采用相同的采样率和采样位数
常见问题
i2s的rx所有的clk都有,tx所有的clk都没有
调试思路:
检查所有的aic时钟寄存器是否都设置对了?
录音的时候发现录出的左声道声音音量很小,而右声道声音正常
调试思路:
1.检查软件的问题,单独录取左右声道音频数据。
2.检查了硬件问题,测量从麦克风或拾音器拾取的音频信号。
播放速度变快或者变慢的问题
  1. 当lrclk的时钟频率 > 播放音频文件的采样率时,会出现声音变快的现象
  2. 当lrclk的时钟频率 < 播放音频文件的采样率时,会出现声音变慢的现象
underrun/overrun问题
underrun:一般出现在放音时,当上层的数据没有及时的送到驱动的buffer中时,导致驱动出现无数据可读的情况,即会出现underrun错误
overrun:一般出现在录音时,当上层没有及时取走驱动buffer中的数据时,导致驱动buffer出现无空间可写的情况,即会出现overrun错误
pcm_read:2145: read error: Input/output error
导致这个问题的根本原因是aplay写到环形buffer中的数据未被拿走,或者arecord从buffer中拿取数据时拿不到数据,调试思路:
1.查看对应的gpio function对不对
2.查看是否有相关时钟
3.查看dma相关操作是否存在问题
Unable to install hw params
硬件支持该音频参数,但在驱动配置音频参数时缺少该参数的判断导致报错返回。
