eMMC/SD/SDIO 接口
DWC_MSHC是一种可高度配置和可编程的高性能移动存储主控制器。DWC_MSHC其数据传输的总接口为AXI。EMMC
是英文 Embedded Multi-Media Card(嵌入式多媒体卡)的缩写,X2000支持EMMC协议Electrical
Standard(5.1)。
X2000使用的ap6256芯片。 AP6256是基于BCM4345C5方案的集成wifi和bluetooth的功能模块,它包括用于WiFi的SDIO接口,和用于蓝牙的UART/PCM接口。
GPIO功能描述:
EMMC
| Name | I/O | Funtion |
| MSC0_CLK |
GPIO-PD17 |
FUNTION0 |
| MSC0_CMD |
GPIO-PD18 |
FUNTION0 |
| MSC0_DATA |
GPIO-(PD19~PD26) |
FUNTION0 |
SDIO
| SDIO |
GPIO-(PD08~PD13) |
FUNTION0 |
| WL_REG_ON |
GPIO-PD0 |
| WL_WAKE_HOST |
GPIO-PD1 |
SD
| MSC0_CLK |
GPIO-PE00 |
FUNTION0 |
| MSC0_CMD |
GPIO-PE01 |
FUNTION0 |
| MSC0_DATA |
GPIO-(PE02~PE05) |
FUNTION0 |
MSC控制器命名对应关系:
| 控制器 | Base | bootrom | kernel | pm-spec | hardware-pcd |
| 控制器0 |
13450000 |
msc0 |
msc0 |
msc0 |
msc0 |
| 控制器1 |
13460000 |
msc1 |
msc1 |
sdio |
sdio |
| 控制器2 |
13490000 |
Msc2 |
msc2 |
msc1 |
msc1 |
驱动源码位于:
module_drivers/drivers/mmc/host/
├──sdhci.c
├──sdhci-ingenic.c
├──ingenic_sdio.c
msc0控制器描述:
msc0: msc@0x13450000 {
compatible = "ingenic,sdhci";
reg = <0x13450000 0x10000>;
status = "disabled";
interrupts = <IRQ_MSC0>;
msc1控制器描述:
msc1: msc@0x13460000 {
reg = <0x13460000 0x10000>;
interrupts = <IRQ_MSC1>;
msc2控制器描述:
msc2: msc@0x13490000 {
reg = <0x13490000 0x10000>;
interrupts = <IRQ_MSC2>;
在板级设备树halley5_v30.dts中,默认配置产生msc1 msc2设备,描述如下:
EMMC
&msc0 {
status = "disable";
/*mmc-hs200-1_8v;*/
cap-mmc-highspeed;
non-removable;
max-frequency = <50000000>;
bus-width = <4>;
non-removable;
voltage-ranges = <1800 3300>;
/* special property */
wp-gpios = <0>;
cd-gpios = <0>;
ingenic,rst-gpios = <0>;
SDIO
&msc1 {
pinctrl-names ="default","enable", "disable";
pinctrl-0 = <&msc1_4bit>;
pinctrl-1 = <&rtc32k_enable>;
pinctrl-2 = <&rtc32k_disable>;
sd-uhs-sdr104;
max-frequency = <100000000>;
bus-width = <4>;
non-removable;
ingenic,sdio_clk = <1>;
keep-power-in-suspend;
ingenic,sdr-gpios = <0>;
wp-gpios = <0>;
ingenic,removal-manual; /*removal-dontcare, removal-nonremovable, removal-removable, removal-manual*/
bcmdhd_wlan: bcmdhd_wlan {
compatible = "android,bcmdhd_wlan";
ingenic,sdio-irq = <&gpd 0 IRQ_TYPE_LEVEL_HIGH INGENIC_GPIO_NOBIAS>;
ingenic,sdio-reset = <&gpd 1 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
SD
&msc2 {
pinctrl-names ="default";
pinctrl-0 = <&msc2_4bit>;
sd-uhs-sdr104;
max-frequency = <200000000>;
/*cd-inverted;*/
bus-width = <4>;
cd-gpios = <&gpc 12 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
ingenic,sdr-gpios = <&gpc 0 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
EMMC
| 属性名称 | 说明 |
| mmc-hs200-1_8v |
配置emmc支持hs200传输模式 |
| cap-mmc-highspeed |
配置emmc支持highspeed传输模式 |
| non-removable |
配置emmc属性为不可移动卡 |
| max-frequency |
通过配置该参数来指定当前模式下最大频率 |
| enable_cpm_rx_tuning |
该选项用于设置手动调试MSC rx相位,默认控制器自动tuning |
选项用于设置手动调试MSC tx相位 |
| bus-width |
配置数据总线宽度,支持1bit、4bit、8bit |
| voltage-ranges |
指定电压范围 |
| wp-gpios |
写保护 |
| cd-gpios |
卡检查 |
| ingenic,rst-gpios |
硬件reset |
SDIO
| 属性名称 | 说明 |
| sd-uhs-sdr104 |
sdr104模式 |
| max-frequency |
| bus-width |
| voltage-ranges |
指定电压范围 |
| ingenic,sdio_clk |
| keep-power-in-suspend |
休眠保持供电 |
| wp-gpios |
写保护 |
| cd-gpios |
卡检查 |
| ingenic,rst-gpios |
硬件reset |
| ingenic,removal-manual |
removal-dontcare, removal-nonremovable, removal-removable, removal-manual |
| ingenic,sdio-irq |
Wifi中断 |
| ingenic,sdio-reset |
Wifi reset |
SD
| 属性名称 | 说明 |
| sd-uhs-sdr104 |
sdr104模式 |
| max-frequency |
| cd-inverted |
配置支持SD卡热插拔 |
| bus-width |
| voltage-ranges |
指定电压范围 |
| ingenic,sdr-gpios |
通过GPIO配置SD卡外部电路3.3V到1.8V电压切换 |
| wp-gpios |
配置CD pin用于SD卡检测 |
| ingenic,rst-gpios |
硬件reset |
内核Block & wireless基础编译配置
Block基础编译配置
Device Drivers --->
--- MMC/SD/SDIO card support
<*> HW reset support for eMMC
<*> Simple HW reset support for MMC
<*> MMC block device driver
(16) Number of minors per block device
< > SDIO UART/GPS class support
< > MMC host test driver
*** MMC/SD/SDIO Host Controller Drivers ***
[ ] MMC host drivers debugging
-*- Secure Digital Host Controller Interface support
< > SDHCI platform and OF driver helper
< > MMC/SD/SDIO over SPI
< > Synopsys DesignWare Memory Card Interface
< > Ingenic JZ47xx SD/Multimedia Card Interface support
< > VUB300 USB to SDIO/SD/MMC Host Controller support
Wireless基础编译配置
Device Drivers
--- Network device support
[*] Network core driver support
[*] Wireless LAN --->
EMMC/SD/SDIO控制器驱动配置
Symbol: MMC_SDHCI_INGENIC [=y]
Type : tristate
Prompt: Ingenic(XBurst2) MMC/SD Card Controller(MSC) support
-> [MSC] (eMMC/SD/SDIO) and Device Drivers
Depends on: MMC [=y]
Selects: MMC_SDHCI [=y]
wifi驱动配置
SDIO-WIFI drivers
<*> Broadcom FullMAC wireless cards support
(/firmware/fw_bcm43456c5_ag.bin) Firmware path
(/firmware/nvram_ap6256.txt) NVRAM path
Enable Chip Interface (SDIO bus interface support) --->
Interrupt type (Out-of-Band Interrupt) --->
| 内核配置名称 | 说明 |
| MMC_BLOCK_MINORS |
每个块设备的最大分区数 |
| BCMDHD_FW_PATH |
配置wifi模块固件路径 |
| BCMDHD_NVRAM_PATH |
配置wifi模块固件路径 |
内核版本差异
无
EMMC
驱动加载成功:
[ 1.575803] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[ 1.593001] mmcblk0: mmc1:aaaa SC16G 14.8 GiB
[ 1.601920] Alternate GPT is invalid, using primary GPT.
[ 1.607432] mmcblk0: p1 p2 p3 p4 p5 p6 p7
产生设备节点:
/dev/mmcblk0 /dev/mmcblk0p1~p7 /*对应emmc的分区*/
SDIO
驱动加载成功:
1.124644] Dongle Host Driver, version 1.363.59.144.11 (r) [ 1.124644]
Compiled from [ 1.125120] Register interface [wlan0] MAC:
00:90:4c:11:22:33 [ 1.125120] [ 1.125195] dhd_module_init: Exit err=0
SD
驱动加载成功:
产生设备节点:
/dev/mmcblk0/dev/mmcblk0p1~p7 /*对应sd的分区*/
EMMC/SD测试方法
写测试
# dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=100 conv=fsync
读测试
# sync; echo 3 > proc/sys/vm/drop_caches
# time dd if=/dev/mmcblk0 of=/dev/null bs=1M count=100
SDIO测试方法
配置网络方法
1. /etc/wpa_supplicant
# cat /etc/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
update_config=1
country=GB"
network={
ssid="Guest" /*连接WiFi账户*/
psk="ingenic*123" /*连接Wifi密码*/
bssid=
priority=1
2. 执行wifi_up.sh
# wifi_up.sh
[ 13.285811] dhd_open: Enter 843c4800
[ 13.290329] dhd_conf_read_config: Ignore config file /firmware/config.txt
[ 13.297356] Final fw_path=/firmware/fw_bcm43456c5_ag.bin
[ 13.302873] Final nv_path=/firmware/nvram_ap6256.txt
[ 13.308002] Final clm_path=/firmware/clm_bcmdhd.blob
[ 13.313152] Final conf_path=/firmware/config.txt
[ 13.317926] dhd_set_bus_params: set use_rxchain 0
[ 13.322804] dhd_set_bus_params: set txglomsize 36
[ 13.328047] dhd_os_open_image: /firmware/fw_bcm43456c5_ag.bin (579388 bytes) open success
[ 13.409630] dhd_os_open_image: /firmware/nvram_ap6256.txt (2440 bytes) open success
[ 13.516230] bcmsdh_oob_intr_register: HW_OOB enabled
[ 13.521376] bcmsdh_oob_intr_register OOB irq=72 flags=0x4
[ 13.556873] Firmware up: op_mode=0x0005, MAC=c0:84:7d:31:c8:c8
[ 13.640263] dhd_txglom_enable: enable 1
[ 13.748733] dhd_open: Exit ret=0
/#udhcpc: started, v1.26.2
Successfully initialized wpa_supplicant
[ 16.320669] Connecting with 8c:0c:90:98:47:cd ssid "wifi ssid", len (5) channel=153
[ 16.367807] wl_bss_connect_done succeeded with 8c:0c:90:98:47:cd
[ 16.401524] wl_bss_connect_done succeeded with 8c:0c:90:98:47:cd
udhcpc: sending select for 10.4.30.146
adding dns 219.141.136.10
adding dns 202.106.0.20
3. 执行ping命令连网
/#ping www.baidu.com
PING www.baidu.com (220.181.38.150): 56 data bytes
64 bytes from 220.181.38.150: seq=0 ttl=53 time=14.347 ms
64 bytes from 220.181.38.150: seq=1 ttl=53 time=9.873 ms
64 bytes from 220.181.38.150: seq=2 ttl=53 time=12.889 ms
airkiss配网测试
AirKiss是微信硬件平台为Wi-Fi设备提供的微信配网、局域网发现和局域网通讯的技术。
1. 配网
注:以下操作必须在WIFI(外网)环境下配置
使用AirkissDubugger软件(手机端下载)配置wifi
2. 执行airkiss命令
# airkiss
[ 113.669340] dhd_open: Enter 842f1000
[ 113.677706] Dongle Host Driver, version 1.579.77.41.26 (r-20200429-2)
[ 113.695902] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 114.122604] F1 signature read @0x18000000=0x15294345
[ 114.130573] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x9 pkg:0x2
[ 114.137706] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[ 114.153611] [dhd] dhd_conf_read_config : Ignore config file /firmware/config.txt
[ 114.161413] [dhd] dhd_conf_set_path_params : Final fw_path=/firmware/fw_bcm43456c5_ag.bin
[ 114.169851] [dhd] dhd_conf_set_path_params : Final nv_path=/firmware/nvram_ap6256.txt
[ 114.177960] [dhd] dhd_conf_set_path_params : Final clm_path=/firmware/clm_bcm43456c5_ag.blob
[ 114.186695] [dhd] dhd_conf_set_path_params : Final conf_path=/firmware/config.txt
[ 114.194942] dhd_os_open_image: /firmware/fw_bcm43456c5_ag.bin (579388 bytes) open success
[ 114.266737] dhd_os_open_image: /firmware/nvram_ap6256.txt (2440 bytes) open success
[ 114.283245] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 114.580570] [dhd-wlan0] wl_android_wifi_on : Success
Easy setup target library v4.0.0
state: 0 --> 1
state: 1 --> 3
state: 3 --> 5
ssid: JZ_SW /*软件端配置的网络账号*/
password: jz_sw%#!135 /*软件端配置的网络密码*/
/etc/wpa_supplicant.conf create successfully!
random: 0xc1
time elapsed: 0s
/#udhcpc: started, v1.31.1
[ 118.985525] [dhd-wlan0] wl_run_escan : LEGACY_SCAN sync ID: 0, bssidx: 0
wlan0: Trying to associate with c4:01:7c:78:c3:dd (SSID='JZ_SW' freq=5765 MHz)
121.338272] [dhd-wlan0] wl_cfg80211_connect : Connecting with
c4:01:7c:78:c3:dd ssid "JZ_SW", len (5), sec=wpa2psk/mfpn/tkipaes,
channel=153
[ 121.402046] [dhd-wlan0] wl_ext_iapsta_event : [S] Link UP with c4:01:7c:78:c3:dd
[ 121.409697] [dhd-wlan0] wl_notify_connect_status : wl_bss_connect_done succeeded with c4:01:7c:78:c3:dd
wlan0: Associated with c4:01:7c:78:c3:dd
wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wlan0: WPA: Key negotiation completed with c4:01:7c:78:c3:dd [PTK=CCMP GTK=TKIP]
wlan0:
CTRL-EV[ 121.451231] [dhd-wlan0] wl_notify_connect_status :
wl_bss_connect_done succeeded with c4:01:7c:78:c3:dd vndr_oui: 00-90-4C
00-13-92
ENT-CONNECTED - Connection to c4:01:7c:78:c3:dd completed [id=0 id_str=]
udhcpc: sending select for 10.10.30.203
udhcpc: lease of 10.10.30.203 obtained, lease time 86400
adding dns 192.168.1.2
3. 执行ping命令连接网络
# ping www.baidu.com
AP模式使用方法
1. AP模式下的配置文件(/etc/hostapd.conf)
interface=wlan0
driver=nl80211
ssid=ingenic
channel=1
hw_mode=g
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
#wpa=2
#wpa_passphrase=12345678
#wpa_key_mgmt=WPA-PSK
#wpa_pairwise=TKIP
#rsn_pairwise=CCMP
2. 进入AP模式
# wifi_ap_mode_start.sh
wlan0: interface state UNINITIALIZED->ENABLED
wlan0: AP-ENABLED
3. 执行ifconfig,查看连接信息
# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr C0:84:7D:6A:F1:CD
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:46 errors:0 dropped:21 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:6509 (6.3 KiB) TX bytes:744 (744.0 B)
4. 使用手机(或电脑)连接wifi
连接SSID为“ingenic”对应配置文件ssid=ingenic,密码可以使用wpa_passphrase = 12345678指定(本测试未设置密码)
连接成功会打印如下信息:
[ 515.831824] [dhd-wlan0] wl_ext_iapsta_event : [A] connected device 00:26:c6:58:50:54
[ 515.839828] [dhd-wlan0] wl_notify_connect_status_ap : connected device 00:26:c6:58:50:54
[ 515.851919] [dhd] CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
udhcpd: sending OFFER to 192.168.1.2
udhcpd: sending ACK to 192.168.1.2
5. 连接成功,Ping网络测试
# ping 192.168.1.2
PING 192.168.1.2 (192.168.1.2): 56 data bytes
64 bytes from 192.168.1.2: seq=0 ttl=64 time=8.148 ms
64 bytes from 192.168.1.2: seq=1 ttl=64 time=15.411 ms
64 bytes from 192.168.1.2: seq=2 ttl=64 time=12.505 ms
64 bytes from 192.168.1.2: seq=3 ttl=64 time=7.654 ms
64 bytes from 192.168.1.2: seq=4 ttl=64 time=7.505 ms
