Hash模块驱动接口
• 支持hash算法加速,支持SHA1 RFC-3174标准和MD5 RFC-1321标准
• 支持SHA 160/224/256/384/512
• 支持MD5 128bit
module_drivers/drivers/crypto/ingenic-hash.c
kernel内核dts文件路径:
Hash控制器定义:
hash: hash@0x13470000 {
compatible = "ingenic,hash";
reg = <0x13470000 0x10000>;
interrupts = <IRQ_HASH>;
status = "ok";
设备树默认编译会产生hash设备。
用户可根据实际需求关闭hash设备,将该节点配置为disabled。
内核驱动编译选项CRYPTO_DEV_INGENIC_SHA
Symbol: CRYPTO_USER_API_HASH [=y]
Type : tristate
Prompt: User-space interface for hash algorithms
(1) -> Cryptographic API (CRYPTO [=y])
Defined at crypto/Kconfig:1607
Depends on: CRYPTO [=y] && NET [=y]
Selects: CRYPTO_HASH [=y] && CRYPTO_USER_API [=n]
Symbol: CRYPTO_DEV_INGENIC_SHA [=y]
Type : tristate
Prompt: Support for Ingenic SHA hw accelerator
-> Hardware crypto devices (CRYPTO_HW [=n])
Prompt: [SHA] Support for Ingenic SHA hw accelerator
Defined at drivers/crypto/Kconfig:493
Depends on: CRYPTO [=y] && CRYPTO_HW [=n] && (MACH_XBURST [=y] || MACH_XBURST2 [=n])
Selects: CRYPTO_ALGAPI [=y] && CRYPTO_ALGAPI [=y]
内核默认编译会产生Hash控制器设备。配置界面如下:
用户可根据实际需求关闭该设备。
/sys/bus/platform/drivers/hash
参考应用测试程序路径:
packages/example/security_utils/hash/
├── CMakeLists.txt
├── hash.c
├── hash_openssl.c
├── include
│ ├── bignum.h
│ ├── hash.h
│ └── hash_openssl.h
└── main.c
测试方法:
# hash_test in_file out_file
in_file为待加密数据文件名,加密成功数据将存于out_file文件。
相关测试数据:
packages/example/security_utils/test_data/hash_test/
├── hash_result.txt
└── hash_test_data.txt
• hash_result.txt:该数据为结果数据
• hash_test_data.txt:该数据为待测试数据
# hash_test hash_test_data.txt hash_result.txt
加密成功后打印:
hash crypt success!!
