SMB I2C接口
SMB总线是两线串行接口,由串行数据线(SDA)和串行时钟(SCL)组成,这些电线在连接到总线的设备之间传送信息。每个设备都有一个唯一的地址,并且可以根据设备的功能充当“发送器”或“接收器”,在执行数据传输时,设备也可以视为主机或从机。主设备是初始化/终止总线上的数据传输并生成时钟信号以允许该传输的设备。在这段时间内,任何寻址的设备都被视为从设备,SMB控制器是软件控制的,它充当主机或从机,但是,不支持同时作为主机和从机运行。
i2c控制器为SMB,SMB支持的接口有i2c,支持100 Kb/s和400 Kb/s,I2C接口可连接至pmu, camera,通过i2c接口进行配置。
驱动位置
驱动源码位于
module_drivers/drivers/i2c/busses/i2c-ingenic.c
I2C控制器描述:
i2c0: i2c@0x10050000 {
 compatible = "ingenic,x2000-i2c";
 reg = <0x10050000 0x1000>;
 interrupts = <IRQ_I2C0>;
 #address-cells = <1>;
 #size-cells = <0>;
i2c1: i2c@0x10051000 {
i2c2: i2c@0x10052000 {
i2c3: i2c@0x10053000 {
i2c4: i2c@0x10054000 {
i2c5: i2c@0x10055000 {
设备树默认编译会产生i2c-adapter0设备和i2c-adapter3设备
用户可根据实际需求打开或关闭某个i2c adapter设备,并在设备树的i2c-adapter节点下挂接相应的i2c-client设备。例如:
 &i2c3 {
 clock-frequency = <100000>;
 timeout = <1000>;
 pinctrl-names = "default";
 pinctrl-0 = <&i2c3_pa>;
 ov2735_0:ov2735@0x3d {
 status = "ok";
 compatible = "ovti,ov2735b";
 reg = <0x3d>;
 pinctrl-names = "default", "default";
 pinctrl-0 = <&vic_pa_low_10bit>;
 pinctrl-1 = <&cim_vic_mclk_pe>;
 ingenic,rst-gpio = <&gpa 10 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 ingenic,ircutp-gpio = <&gpb 3 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
 ingenic,ircutn-gpio = <&gpb 0 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
 port {
 ov2735_ep0:endpoint {
 remote-endpoint = <&isp0_ep>;
 bus-width = <10>; /* Used data lines */
 data-shift = <0>; /* Lines 9:0 are used */
 /* If hsync-active/vsync-active are missing,
 embedded BT.656 sync is used */
 hsync-active = <1>; /* Active high */
 vsync-active = <1>; /* Active high */
 data-active = <1>; /* Active high */
 pclk-sample = <1>; /* Rising */
内核配置
内核配置I2C_INGENIC,配置说明如下:
Symbol: I2C_INGENIC [=y]
Type : boolean
Prompt: Ingenic SoC based on Xburst arch's I2C controler Driver support
 -> Device Drivers
 -> I2C support
 -> I2C support (I2C [=y])
 -> I2C Hardware Bus support
 -> [I2C] Master Drivers
 Defined at drivers/i2c/busses/Kconfig
内核默认配置I2C控制器驱动,配置界面如下:
1.用户可根据实际需求去掉I2C控制器的驱动。
2.可将设备节点导出到用户空间的/dev下,配置I2C_CHARDEV,配置说明如下:
Symbol: I2C_CHARDEV [=y]
Type : tristate
Prompt: I2C device interface
 -> Device Drivers
 -> I2C support
 Defined at module_drivers/drivers/i2c/Kconfig
 Depends on: I2C [=y]
配置界面如下:
模块内核差异
无
GPIO模拟i2c
1. 首先需要选取两组未使用的GPIO用来模拟sda、scl。
2. 设备树中自定义配置
i2c@0 {
 compatible = "i2c-gpio";
 gpios = <&gpc 31 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>,/* sda */
 <&gpc 30 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;/* scl */
 //i2c-gpio,sda-open-drain;
 //i2c-gpio,scl-open-drain;
 i2c-gpio,delay-us = <2>; /* ~100 kHz */
 #size-cells = <0>;
3.在内核自定义编译配置中选择
配置说明:
Symbol: I2C_GPIO [=y]
Type : tristate
Prompt: GPIO-based bitbanging I2C
 -> Device Drivers
 -> I2C support
打开I2C_CHARDEV选项后将在/dev下生成相应的节点:
# ls /dev/i2c-
i2c-0 i2c-2 i2c-3 i2c-4
常见i2c通信内核提示:
错误提示说明
I2C_TXABRT_ABRT_7B_ADDR_NOACK 7bit寻址下,slave未回ACK
I2C_TXABRT_ABRT_10ADDR1_NOACK 10bit寻址下,发送第一字节后未应答
I2C_TXABRT_ABRT_10ADDR2_NOACK 10bit寻址下,发送第二字节后未应答
I2C_TXABRT_ABRT_XDATA_NOACK 地址确定后,但后续数据slave未应答
I2C_TXABRT_ABRT_GCALL_NOACK i2c广播寻址,slave未应答
I2C_TXABRT_ABRT_GCALL_READ i2c广播寻址后,进行读操作
I2C_TXABRT_ABRT_HS_ACKD 主设备处于高速模式下并被确认
I2C_TXABRT_SBYTE_ACKDET 主设备已经发送一个字节,并且开始字节被确认
I2C_TXABRT_ABRT_HS_NORSTRT 重启不可用,但用户想要 在高速模式下发送数据
I2C_TXABRT_SBYTE_NORSTRT 重启不可用,但用户发送了一个开始字节
I2C_TXABRT_ABRT_10B_RD_NORSTRT 重启不可用,但主设备在10bit寻址下发送读命令
I2C_TXABRT_ABRT_MASTER_DIS 当前主设备不可用,用户对主设备进行操作
I2C_TXABRT_ARB_LOST 失去仲裁
I2C_TXABRT_SLVFLUSH_TXFIFO 当从设备要接收数据时,fifo里已经有一些数据了
I2C_TXABRT_SLV_ARBLOST 当发送数据时,从设备丧失总线
I2C_TXABRT_SLVRD_INTX 当主设备需要发送数据时,却进入了读数据状态
