SMB I2C接口
SMB总线是两线串行接口,由串行数据线(SDA)和串行时钟(SCL)组成,这些电线在连接到总线的设备之间传送信息。每个设备都有一个唯一的地址,并且可以根据设备的功能充当“发送器”或“接收器”,在执行数据传输时,设备也可以视为主机或从机。主设备是初始化/终止总线上的数据传输并生成时钟信号以允许该传输的设备。在这段时间内,任何寻址的设备都被视为从设备,SMB控制器是软件控制的,它充当主机或从机,但是,不支持同时作为主机和从机运行。
i2c 控制器为 SMB,SMB 支持的接口有 i2c,支持 100 Kb/s 和 400 Kb/s,I2C 接口可连接至 pmu, camera,通过 i2c 接口进行配置。
驱动位置
驱动源码位于
module_drivers/drivers/i2c/busses/i2c-ingenic.c
i2c控制器描述:
i2c0: i2c@0x10050000 {
compatible = "ingenic,x2000-i2c";
reg = <0x10050000 0x1000>;
interrupts = <IRQ_I2C0>;
#address-cells = <1>;
#size-cells = <0>;
i2c1: i2c@0x10051000 {
i2c2: i2c@0x10052000 {
i2c3: i2c@0x10053000 {
i2c4: i2c@0x10054000 {
i2c5: i2c@0x10055000 {
};设备树默认配置
设备树默认编译会产生i2c-adapter0设备和i2c-adapter3设备
用户可根据实际需求打开或关闭某个i2c adapter设备,并在设备树的i2c-adapter节点下挂接相应的i2c-client设备。例如:
&i2c3 {
clock-frequency = <100000>;
timeout = <1000>;
pinctrl-names = "default";
pinctrl-0 = <&i2c3_pa>;
ov2735_0:ov2735@0x3d {
status = "ok";
compatible = "ovti,ov2735b";
reg = <0x3d>;
pinctrl-names = "default", "default";
pinctrl-0 = <&vic_pa_low_10bit>;
pinctrl-1 = <&cim_vic_mclk_pe>;
ingenic,rst-gpio = <&gpa 10 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
ingenic,ircutp-gpio = <&gpb 3 GPIO_ACTIVE_HIGH INGENIC_GPIO_NOBIAS>;
ingenic,ircutn-gpio = <&gpb 0 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;
port {
ov2735_ep0:endpoint {
remote-endpoint = <&isp0_ep>;
bus-width = <10>; /* Used data lines */
data-shift = <0>; /* Lines 9:0 are used */
/* If hsync-active/vsync-active are missing,
embedded BT.656 sync is used */
hsync-active = <1>; /* Active high */
vsync-active = <1>; /* Active high */
data-active = <1>; /* Active high */
pclk-sample = <1>; /* Rising */
};内核配置
内核配置I2C_INGENIC,配置说明如下:
Symbol: I2C_INGENIC [=y] Type : boolean Prompt: Ingenic SoC based on Xburst arch's I2C controler Driver support Location: -> Device Drivers -> I2C support -> I2C support (I2C [=y]) -> I2C Hardware Bus support Prompt: Ingenic SoC based on Xburst arch's I2C controler Driver support Location: -> Ingenic device-drivers Configurations -> [I2C] Master Drivers Defined at drivers/i2c/busses/Kconfig
内核默认配置I2C控制器驱动,配置界面如下:
1.用户可根据实际需求去掉I2C控制器的驱动。
2.可将设备节点导出到用户空间的/dev下,配置I2C_CHARDEV,配置说明如下:
Symbol: I2C_CHARDEV [=y] Type : tristate Prompt: I2C device interface Location: -> Device Drivers -> I2C support -> I2C support (I2C [=y]) Defined at module_drivers/drivers/i2c/Kconfig Depends on: I2C [=y]
配置界面如下:
模块内核差异
无
GPIO模拟i2c
首先需要选取两组未使用的GPIO用来模拟sda、scl。
设备树中自定义配置
i2c@0 {
compatible = "i2c-gpio";
gpios = <&gpc 31 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>,/* sda */
<&gpc 30 GPIO_ACTIVE_LOW INGENIC_GPIO_NOBIAS>;/* scl */
//i2c-gpio,sda-open-drain;
//i2c-gpio,scl-open-drain;
i2c-gpio,delay-us = <2>; /* ~100 kHz */
#size-cells = <0>;
};3.在内核自定义编译配置中选择
配置说明:
Symbol: I2C_GPIO [=y] Type : tristate Prompt: GPIO-based bitbanging I2C Location: -> Device Drivers -> I2C support -> I2C support (I2C [=y]) -> I2C Hardware Bus support Defined at drivers/i2c/busses/Kconfig
打开I2C_CHARDEV选项后将在/dev下生成相应的节点:
# ls /dev/i2c- i2c-0 i2c-2 i2c-3 i2c-4
常见i2c通信内核提示:
| 错误提示 | 说明 |
| I2C_TXABRT_ABRT_7B_ADDR_NOACK | 7bit寻址下,slave未回ACK |
| I2C_TXABRT_ABRT_10ADDR1_NOACK | 10bit寻址下,发送第一字节后未应答 |
| I2C_TXABRT_ABRT_10ADDR2_NOACK | 10bit寻址下,发送第二字节后未应答 |
| I2C_TXABRT_ABRT_XDATA_NOACK | 地址确定后,但后续数据slave未应答 |
| I2C_TXABRT_ABRT_GCALL_NOACK | i2c广播寻址,slave未应答 |
| I2C_TXABRT_ABRT_GCALL_READ | i2c广播寻址后,进行读操作 |
| I2C_TXABRT_ABRT_HS_ACKD | 主设备处于高速模式下并被确认 |
| I2C_TXABRT_SBYTE_ACKDET | 主设备已经发送一个字节,并且开始字节被确认 |
| I2C_TXABRT_ABRT_HS_NORSTRT | 重启不可用,但用户想要 在高速模式下发送数据 |
| I2C_TXABRT_SBYTE_NORSTRT | 重启不可用,但用户发送了一个开始字节 |
| I2C_TXABRT_ABRT_10B_RD_NORSTRT | 重启不可用,但主设备在10bit寻址下发送读命令 |
| I2C_TXABRT_ABRT_MASTER_DIS | 当前主设备不可用,用户对主设备进行操作 |
| I2C_TXABRT_ARB_LOST | 失去仲裁 |
| I2C_TXABRT_SLVFLUSH_TXFIFO | 当从设备要接收数据时,fifo里已经有一些数据了 |
| I2C_TXABRT_SLV_ARBLOST | 当发送数据时,从设备丧失总线 |
| I2C_TXABRT_SLVRD_INTX | 当主设备需要发送数据时,却进入了读数据状态 |
