SFC控制器
SFC 是spi master设备,用来控制spi flash。支持CPU模式和DMA模式传输。
• 支持CDT命令传输模式。
• 支持DMA descriptor chain数据传输模式。
• 支持硬件polling flash的状态。
• 支持Standard, Dual, Quad, Octal SPI等多种传输协议。
module_drivers/drivers/mtd/devices/ingenic_sfc_v2/
├── fmw.h
├── ingenic_sfc_common.c
├── ingenic_sfc_common.h
├── ingenic_sfc_drv.c
├── ingenic_sfc_drv.h
├── ingenic_sfc_nand.c
├── ingenic_sfc_nor.c
├── ingenic_sfc_ops.c
├── Makefile
├── nand_device
│   ├── ato_nand.c
│   ├── dosilicon_nand.c
│   ├── fm_nand.c
│   ├── foresee_nand.c
│   ├── gd_nand.c
│   ├── issi_nand.c
│   ├── Makefile
│   ├── mxic_nand.c
│   ├── nand_common.c
│   ├── nand_common.h
│   ├── toshiba_nand.c
│   ├── winbond_nand.c
│   ├── xcsp_nand.c
│   ├── xtx_mid0b_nand.c
│   ├── xtx_mid2c_nand.c
│   ├── xtx_nand.c
│   ├── yhy_nand.c
│   └── zetta_nand.c
├── nor_device
│   ├── Makefile
│   ├── nor_device.c
│   └── nor_device.h
├── sfc_flash.h
├── sfc.h
├── spinand_cmd.h
├── spinand.h
├── spinor_cmd.h
└── spinor.h
SFC控制器描述:
sfc:sfc@0x13440000 {
compatible = “ingenic,sfc”;
reg = <0x13440000 0x10000>;
interrupts = <IRQ_SFC>;
设备树默认编译会产生sfc设备
&sfc {
 pinctrl-names = "default";
 pinctrl-0 = <&sfc_pe>;
ingenic,sfc-init-frequency = <200000000>;
 ingenic,sfc-max-frequency = <400000000>;
 ingenic,use_ofpart_info = /bits/ 8 <0>;
 ingenic,spiflash_param_offset = <0>;
 norflash@0 {
 partitions {
 compatible = "fixed-partitions";
 #address-cells = <1>;
 #size-cells = <1>;
 /* spi nor flash partition */
 uboot@0 {
 label = "uboot";
 reg = <0x0000000 0x40000>;
 /*read-only;*/
 kernel@40000 {
 label = "kernel";
 reg = <0x40000 0x300000>;
 rootfs@360000 {
 label = "rootfs";
 reg = <0x360000 0xca0000>;
 nandflash@1 {
 partitions {
 #size-cells = <1>;
 /* spi nand flash partition */
 partition@0 {
 label = "uboot";
 reg = <0x0000000 0x100000>;
 /*read-only;*/
 partition@100000 {
 label = "kernel";
 reg = <0x100000 0x800000>;
 partition@900000 {
 label = "rootfs";
 reg = <0x900000 0xf700000>;
用户可根据实际需求关闭该节点,或进行以下配置:
属性名称说明
ingenic,sfc-init-frequency sfc控制器在初始化阶段设置的时钟频率,因为未经过时序参数的配置,所以频率较低。
ingenic,sfc-max-frequency 配置sfc最大频率,需要经过4分频,实际线上时钟为(sfc-max-frequency/4)MHz。
ingenic,use_ofpart_info 默认情况下,MTD分区由烧录工具传入,当配置该节点为1时,则使用设备树分区信息。
ingenic,spiflash_param_offset 当使用spi flash存放flash参数和分区信息时, 用于修改spi flash中存放参数的偏移地址。当值为0时,默认偏移为0x5800。
内核配置INGENIC_SFC,配置说明如下:
Symbol: INGENIC_SFC [=y]
Type : tristate
 Prompt: Ingenic series SFC driver
 -> [SFC] (SPI Nand/Nor Flash) Drivers
Defined at module_drivers/drivers/mtd/devices/Kconfig:1
Depends on: MACH_XBURST [=n] || MACH_XBURST2 [=y]
默认情况下,内核会配置SFC驱动,如下
Ingenic device-drivers Configurations  --->
[SFC] (SPI Nand/Nor Flash) Drivers  --->
NAND:
<*> Ingenic series SFC driver
Select Ingenic series SFC driver version (Use ingenic sfc driver version 2) --->
the SFC external memory (nor or nand) (Support ingenic sfc-nand) --->
[ ] ingenic SN and MAC read write support.
NOR:
 the SFC external memory (nor or nand) (Support ingenic sfc-nor) --->
[ ] Use SPI Nor Flash params built in kernel (NEW) --->
1. NAND:
NAND预留空间功能,用于存储SN号、MAC地址、License等信息的区域,可配置预留区域 的大 小,默认单个区域大小为1MB。
默认不启用该功能。
Symbol: INGENIC_SFCNAND_FMW [=y]
Type  : bool
Defined at module_drivers/drivers/mtd/devices/Kconfig:44
  Prompt: ingenic SN and MAC read write support.
  Depends on: INGENIC_SFC [=y] && MTD_INGENIC_SFC_NANDFLASH [=y]
        -> Ingenic series SFC driver (INGENIC_SFC [=y])
[*] ingenic SN and MAC read write support.
1. SN space size (MB) (NEW)
(1) MAC space size (MB) (NEW)
(1) LICENSE space size (MB) (NEW)
1. NOR:
启用内核中包含的NOR flash参数,该功能会优先使用内核中的nor flash参数。
(支持多选,但ID相同的flash只能选一个)
默认不启用该功能。
Symbol: INGENIC_BUILTIN_PARAMS [=y]
Type  : bool
Defined at module_drivers/drivers/mtd/devices/Kconfig:70
  Prompt: Use SPI Nor Flash params built in kernel
  Depends on: INGENIC_SFC [=y] && MTD_INGENIC_SFC_NORFLASH [=y]
--- Use SPI Nor Flash params built in kernel
[ ]   GD25Q127C 0xc84018 (NEW)
[ ]   GD25Q256C 0xc84019 (NEW)
[ ]   GD25S512MD 0xc84019 (NEW)
驱动加载成功后生成以下节点:
/dev/mtd
MTD字符设备节点
**/dev/mtdblock ***
MTD块设备节点
flash读写测试
1. 执行脚本: StorageMedia-Test.sh
# ./StorageMedia-Test.sh
* * Please input which module you want test .
* Enter 1 : Read/Write test in the nand/nor .
* Enter 2 : Read/Write test in the sdcard .
* Enter 3 : Read/Write test in the ddr .
* Enter 4 : Read/Write test between nand/nor and sdcard .
* Enter 5 : Read/Write test between nand/nor and ddr .
* Enter 6 : Read/Write test between ddr and sdcard .
2. 输入1
You select 1, nand/nor <-> nand/nor
* * Please choice which Size you want copy .
* Enter 1 : auto random Size
* Enter 2 : setting a fix Size
3. 输入1或输入2
选择1:测试随机大小的数据(根据flash剩余空间,自己计算大小)
选择2:测试指定大小的数据(Kbyte)
4. flash读写测试开始,连续测试一段时间,如果无错误打印、异常退出,则正常。
添加新的flash参数
1.7.1 添加 NOR flash参数
一、通过cloner烧录工具添加spi nor flash参数(推荐)
1.打开cloner中的Config,在INFO菜单下,选择Board为
x2000_sfc_nor_lpddr3_linux.cfg
2.在SFC菜单下,选择二级菜单norinfo,选择ADD。
3.在弹出的对话框中按照spi nor flash的参数填上保存即可。
注: 烧录工具中id号为红色时,表示存在多个相同ID的flash参数,需要手动删除冲突的flash参数
二、在内核中添加NOR flash参数
如果需要添加自定义型号的flash,添加流程如下:
1. 根据flash型号, 添加base params、cdt params、private params参数。参考如下:
module_drivers/drivers/mtd/devices/ingenic_sfc_v2/nor_device/nor_device.c
2. 添加config配置,参考如下:
1.7.2 添加 NAND flash参数
一、添加NAND flash厂商支持
各厂商NAND flash参数配置文件位置
module_drivers/drivers/mtd/devices/ingenic_sfc_v2/nand_device/
若存在该厂商的配置文件,则跳过此步骤;
若不存在,则需要参照其他厂商的参数配置文件,编写自己的配置文件。例如:
$ cp gd_nand.c myflash_nand.c && vi myflash_nand.c
flash参数配置文件主要构成(例如gd_nand.c)
/ 1. flash支持型号的个数 /
define GD_DEVICES_NUM 7
/ 2. flash的基础参数 /
static struct ingenic_sfcnand_base_param gd_param[GD_DEVICES_NUM] = {
[0] = { ...},
/* 3. flash的id和参数建立关联 */
static struct device_id_struct device_id[GD_DEVICES_NUM] = {
DEVICE_ID_STRUCT(0xD1, "GD5F1GQ4UB",&gd_param[0]),
/* 4. flash获取默认的cdt参数,并根据id更新参数*/
static cdt_params_t *gd_get_cdt_params(struct sfc_flash *flash, uint8_t device_id){
/* 5. 使用通用的get feature接口,需要定义处理ecc的接口 */
static inline int deal_ecc_status(struct sfc_flash *flash, uint8_t device_id, uint8_t ecc_status){
/* 6.注册flash参数 */
static int __init gd_nand_init(void) {
二、添加nand flash型号支持
需要对照flash手册,完成以下步骤
1. 添加flash基础参数.
 [6] = {.pagesize = 2 * 1024, ... },
2. 建立flash与参数的关联
DEVICE_ID_STRUCT(0xA1, "GD5F1GQ4RF",&gd_param[6]),
3. 根据id,更新默认参数
case 0xA1:
gd_nand->cdt_params.standard_r.addr_nbyte = 3;
gd_nand->cdt_params.quad_r.addr_nbyte = 3;
break;
4. 在处理ecc的接口中添加对应型号的处理
switch(device_id) {
case 0xA1:
5. 将支持flash总数+1
#define GD_DEVICES_NUM 7
三、对照flash手册比较默认参数,更新参数
默认command参数文件:
module_drivers/drivers/mtd/devices/ingenic_sfc_v2/nand_device/nand_common.h
制作参数接口说明:
控制flash相关:
/CMD_INFO(_CMD, flash命令, dummy bits, 地址长度, 传输协议)/
读flash状态的参数
/ST_INFO(_ST, flash命令, status偏移bit, status状态位的mask, status状态位的期望值, 传输长度, dummy bits)/
例如:
Command NameByte 1Byte 2Byte 3Byte 4Byte 5Byte N
Read From Cache x 4 6BH dummy (2) A15-A8 A7-A0 dummy (2) (D7-D0)x4
/dummy 8bit, 地址长度3,传输协议对应sfc手册:TM_QI_QO_SPI/
CMD_INFO(cdt_params.quad_r, SPINAND_CMD_RDCH_X4, 8, 2, TM_QI_QO_SPI);
RegisterAddr76543210
Status C0H Reserved ECCS2 ECCS1 ECCS0 P_FAIL E_FAIL WEL OIP
/OIP偏移 bit是0, status状态位mask是0x1, 期望值0x0,传输长度1byte, get feature dummy 0bit/
ST_INFO(cdt_params.oip, SPINAND_CMD_GET_FEATURE, 0, 0x1, 0x0, 1, 0);
默认command参数如下
* cdt params
#define CDT_PARAMS_INIT(cdt_params) { \
/* read to cache */ \
CMD_INFO(cdt_params.r_to_cache, SPINAND_CMD_PARD, 0, 3, TM_STD_SPI); \
/* standard read from cache */ \
CMD_INFO(cdt_params.standard_r, SPINAND_CMD_FRCH, 8, 2, TM_STD_SPI); \
/* quad read from cache*/ \
CMD_INFO(cdt_params.quad_r, SPINAND_CMD_RDCH_X4, 8, 2, TM_QI_QO_SPI); \
/* standard write to cache*/ \
CMD_INFO(cdt_params.standard_w_cache, SPINAND_CMD_PRO_LOAD, 0, 2, TM_STD_SPI); \
/* quad write to cache*/ \
CMD_INFO(cdt_params.quad_w_cache, SPINAND_CMD_PRO_LOAD_X4, 0, 2, TM_QI_QO_SPI); \
/* write exec */ \
CMD_INFO(cdt_params.w_exec, SPINAND_CMD_PRO_EN, 0, 3, TM_STD_SPI); \
/* block erase */ \
CMD_INFO(cdt_params.b_erase, SPINAND_CMD_ERASE_128K, 0, 3, TM_STD_SPI); \
/* write enable */ \
CMD_INFO(cdt_params.w_en, SPINAND_CMD_WREN, 0, 0, TM_STD_SPI); \
/* get frature wait oip not busy */ \
ST_INFO(cdt_params.oip, SPINAND_CMD_GET_FEATURE, 0, 0x1, 0x0, 1, 0); \
参数更新(例如gd_nand.c)
static cdt_params_t *gd_get_cdt_params(struct sfc_flash *flash, uint8_t device_id) {
switch(device_id) {
case 0xA1:
gd_nand->cdt_params.standard_r.addr_nbyte = 3; /*地址长度更新为3byte*/
gd_nand->cdt_params.quad_r.addr_nbyte = 3;/*地址长度更新为3byte*/
break;
四、配置get_feature接口
默认get_feature接口位置:
module_drivers/drivers/mtd/devices/ingenic_sfc_v2/nand_device/nand_common.c
可以使用默认的get_feature接口,特殊情况下需要自定义ECC的处理接口
static inline int deal_ecc_status(struct sfc_flash *flash, uint8_t device_id, uint8_t ecc_status) {
switch(device_id) {
case 0xA1:
case 0xB1 ... 0xB4:
switch((ecc_status >> 4) & 0x7) {
case 0x7:
ret = -EBADMSG;
break;
case 0x6:
ret = 0x8;
break;
case 0x5:
ret = 0x7;
break;
default:
ret = 0;
break;
自定义get_feature接口:
1. 在flash参数的配置文件中定义自己的get_feature接口
2. 将自己定义的接口注册到参数中
int32_t my_get_feature(struct sfc_flash *flash, uint8_t flag) {
/* use private get feature interface, please define it in this document */
//gd_nand->ops.get_feature = NULL;
gd_nand->ops.get_feature = my_get_feature();
注意事项
1. Nand Flash ECC方案
使用nand flash自带的硬件ECC, 基于MTD框架,在内存中建立BBT。
2. 当前支持的参数位置
NAND: 目录module_drivers/drivers/mtd/devices/ingenic_sfc_v2/nand_device/下
NOR: 见烧录工具norinfo 界面
3. Kernel可以使用u-boot内置参数,详细参考uboot文档。
需要依赖u-boot,kernel使用默认配置即可。
4. 支持多Die的SPI NOR Flash
spl: 暂不支持多Die切换。
参数: 当flash参数使用烧录方式时,必须存放于Die0。
启动: 支持重启异常时reset flash切换Die0。
5. 使用SFC的PD组GPIO时,要确保PE组GPIO配置成其它function。
注:
a.当PD组和PE组同时配置为sfc function时,优先级PE > PD
b.boot select 选择usb启动或者sfc 1.8v启动
c.选择sfc PD GPIO,修改设备树如下:
例:module_drivers/dts/halley5_v30.dts或module_drivers/dts/x2000/halley5_v30.dts
&sfc {
pinctrl-0 = <&sfc_pd_4bit>;
