DDR模块
DDRC(DDR控制器)是一个通用IP,它提供了LPDDR2和LPDDR3存储器的接口。DDRC IP专为SOC使用而设计,可配置、可扩展以满足各种SOC的要求。
驱动源码
arch/mips/xburst2/common/cpu_ddr_test
├── ddr_bandwidth_monitor.c
├── ddr_bus_protection.c
├── ddr_change_freq.c
DDR模块无设备树配置。
Symbol: XBURST2_CPU_TEST [=y]
Type : boolean
Prompt: xburst2 cpu ddr test
-> Machine selection
(1) -> SOC Type Selection
Defined at arch/mips/xburst2/Kconfig:139
Depends on: MACH_XBURST2 [=y]
驱动加载成功后生成以下debugfs文件节点,需要手动挂载debugfs:
# mount -t debugfs none /mnt
/mnt
├── ddr
├── ddr_config
├── ddrfreq
带宽监测
Debug节点
/mnt/ddr
ahb2_read_rate cpu_read_rate monitors periods
ahb2_write_rate cpu_write_rate output run
命令行及参数示意
1. monitors节点可配置、显示监测的通道,配置需按如下格式,最多可同时监测四通道
#echo 6:3:1:0 > monitors
# cat monitors
monitor:0, chn:6, desc:cpu
read:3046, write:1126
monitor:1, chn:3, desc:dpu&cim
read:279604, write:0
monitor:2, chn:1, desc:vpu&isp
read:0, write:0
monitor:3, chn:0, desc:gmac&msc
read:0, write:0
通道号与模块对应关系如下
{0, "gmac&msc"},
{1, "vpu&isp"},
{3, "dpu&cim"},
{5, "ahb2&audio&apb"},
{6, "cpu"}
2. Period可配置采样的频率,默认25000000
# echo 20000000 > periods
# cat periods
20000000
3. output配置开启、关闭打印log信息
4. run配置启动带宽监测,运行后会依据output配置打印log信息,如下所示:
# echo 1 > run
[60712.288103] cpu chn:6 write occupancy rate:0.036%
[60712.292990] cpu chn:6 read occupancy rate:0.097%
[60712.297757] dpu&cim chn:3 write occupancy rate:0.000%
[60712.303142] dpu&cim chn:3 read occupancy rate:8.947%
[60712.308263] vpu&isp chn:1 write occupancy rate:0.000%
[60712.313602] vpu&isp chn:1 read occupancy rate:0.000%
[60712.318725] gmac&msc chn:0 write occupancy rate:0.000%
[60712.324148] gmac&msc chn:0 read occupancy rate:0.000%
时钟频率
Debug节点
/mnt/ddrfreq
ddr_cur_rate rate
命令行及参数示意
1. ddr_cur_rate、rate节点分别显示ddr时钟频率,单位Hz、MHz。
# cat ddr_cur_rate
500000000
# cat rate
500
参数配置
Debug节点
/mnt/ddr_config
ddr_ahb_protection ddr_driver_strength
ddr_apb_protection ddr_odt
ddr_transaction_priority ddr_port_priority
ddr_bandwidth limit
命令行及参数示意
1. ddr_ahb_protection、ddr_apb_protection节点分别配置ddr ahb、apb总线上的寄存器保护,开启总线保护时,会记录是否发生未许可的读写访问。
# cat ddr_ahb_protection
disable
# echo 1 > ddr_ahb_protection
enable, un-protected register write not occurred
2. ddr_driver_strength节点配置ddr驱动强度,范围0~31.
# cat ddr_driver_strength
22 (range 0 ~ 31), 34.35(ohm)
# echo 31 > ddr_driver_strength
31 (range 0 ~ 31), 20.91(ohm)
3. ddr_transaction_priority节点配置ddr仲裁计数,可读写通道单独配置,格式如下,一般情况下计数越小,仲裁获得优先级越高。
# echo 5:10:5 > ddr_transaction_priority
# echo 6:15 > ddr_transaction_priority
# cat ddr_transaction_priority
range is (0~15)
chn:0, desc:gmac&msc, write priority:8, read priority:8
chn:1, desc:vpu&isp, write priority:8, read priority:8
chn:3, desc:dpu&cim, write priority:8, read priority:8
chn:5, desc:ahb2&audio&apb, write priority:10, read priority:5
chn:6, desc:cpu, write priority:15, read priority:15
4. ddr_port_priority节点配置ddr端口优先级,命令格式如下,1表示高优先级,0表示低优先级。
# echo 6:1>*** ddr_port_priority
# cat*** ddr_transaction_priority
range is (0~1)
chn:6, desc:cpu,***priority:1
chn:5, desc:ahb2&audio&apb,***priority:0
chn:3, desc:dpu&cim,***priority:0
chn:1, desc:vpu&isp,***priority:0
chn:0, desc:gmac&msc,***priority:0
5. ddr_bandwidth_limit节点配置ddr各port带宽限制,可以读写通道单独配置,格式如下,配置值越低,带宽越小,输入-1可以关闭带宽限制。
# echo 6:128 > ddr_bandwidth_limit
# echo 5:32:-1 > ddr_bandwidth_limit
# cat ddr_bandwidth_limit
range is (-1~255)
write:64,disable
read:64.disable
chn:1, desc:vpu&isp
write:64,disable
read:64.disable
chn:3, desc:dpu&cim
write:64,disable
read:64.disable
write:32,enable
read:64.disable
chn:6, desc:cpu
write:128,enable
read:128.enable
