Hash模块驱动接口
支持hash算法加速,支持SHA1 RFC-3174标准和MD5 RFC-1321标准
支持SHA 160/224/256/384/512
支持MD5 128bit
module_drivers/drivers/crypto/ingenic-hash.c
kernel内核dts文件路径:
Hash控制器定义:
hash: hash@0x13470000 {
compatible = "ingenic,hash";
reg = <0x13470000 0x10000>;
interrupts = <IRQ_HASH>;
status = "ok";
};设备树默认配置
设备树默认编译会产生hash设备。
用户可根据实际需求关闭hash设备,将该节点配置为disabled。
内核驱动编译选项CRYPTO_DEV_INGENIC_SHA
Symbol: CRYPTO_USER_API_HASH [=n] Type : tristate Prompt: User-space interface for hash algorithms Location: (1) -> Cryptographic API (CRYPTO [=y]) Defined at crypto/Kconfig:1607 Depends on: CRYPTO [=y] && NET [=y] Selects: CRYPTO_HASH [=y] && CRYPTO_USER_API [=n]
Symbol: CRYPTO_DEV_INGENIC_SHA [=n] Type : tristate Prompt: Support for Ingenic SHA hw accelerator Location: -> Cryptographic API (CRYPTO [=y]) (1) -> Hardware crypto devices (CRYPTO_HW [=n]) Prompt: [SHA] Support for Ingenic SHA hw accelerator Location: (2) -> Ingenic device-drivers Configurations Defined at drivers/crypto/Kconfig:493 Depends on: CRYPTO [=y] && CRYPTO_HW [=n] && (MACH_XBURST [=y] || MACH_XBURST2 [=n]) Selects: CRYPTO_ALGAPI [=y] && CRYPTO_ALGAPI [=y]
内核默认未配置Hash驱动。
用户可根据实际需求配置HASH驱动,配置界面如下:
/sys/bus/platform/drivers/hash
参考应用测试程序路径:
packages/example/security_utils/hash/
├── CMakeLists.txt ├── hash.c ├── hash_openssl.c ├── include │ ├── bignum.h │ ├── hash.h │ └── hash_openssl.h └── main.c
测试方法:
# hash_test in_file out_file
in_file为待加密数据文件名,加密成功数据将存于out_file文件。
相关测试数据:
packages/example/security_utils/test_data/hash_test/
├── hash_result.txt └── hash_test_data.txt
hash_result.txt:该数据为结果数据
hash_test_data.txt:该数据为待测试数据
# hash_test hash_test_data.txt hash_result.txt
加密成功后打印:
hash crypt success!!
