AES 加解密驱动接口
aes对称加解密硬件模块
Rijdael_fips_197 标准
支持128/192/256 CBC/ECB 加解密
内核驱动所在路径:
module_drivers/drivers/crypto/ingenic-aes.c
AES控制器定义:
aes: aes@0x13430000 {
compatible = "ingenic,aes";
reg = <0x13430000 0x10000>;
interrupts = <IRQ_AES>;
status = "ok";
};设备树默认配置
设备树默认编译会产生AES设备。
用户可根据实际需求关闭AES设备,在板级.dts中将该节点配置为disabled。
&aes {
status = "disabled";
};内核编译配置
编译选项: CRYPTO_DEV_INGENIC_AES,配置说明如下:
Symbol: CRYPTO_USER_API_SKCIPHER [=n] Type : tristate Prompt: User-space interface for symmetric key cipher algorithms Location: (1) -> Cryptographic API (CRYPTO [=y]) Defined at crypto/Kconfig:1616 Depends on: CRYPTO [=y] && NET [=y] Selects: CRYPTO_BLKCIPHER [=y] && CRYPTO_USER_API [=y]
Symbol: CRYPTO_DEV_INGENIC_AES [=n] Type : tristate Prompt: Support for INGENIC AES hw engine Location: -> Cryptographic API (CRYPTO [=y]) (1) -> Hardware crypto devices (CRYPTO_HW [=n]) Prompt: [AES] Support for INGENIC AES hw engine Location: (2) -> Ingenic device-drivers Configurations Defined at drivers/crypto/Kconfig:311 Depends on: CRYPTO [=y] && CRYPTO_HW [=n] && (MACH_XBURST [=y] || MACH_XBURST2 [=n]) Selects: CRYPTO_AES [=y] && CRYPTO_BLKCIPHER2 [=y] && CRYPTO_AES [=y] && CRYPTO_BLKCIPHER2 [=y]
内核默认未配置AES驱动。
用户可根据实际需求配置AES驱动,配置界面如下:
驱动加载成功后生成以下节点:
/sys/bus/platform/drivers/aes
测试应用程序路径:
packages/example/security_utils/aes/
├── aes.c ├── CMakeLists.txt ├── gen_key_base.c ├── include │ ├── aes.h │ ├── bignum.h │ ├── gen_key_base.h │ └── keys.h └── main.c
测试方法:
# aes_test in_file out_file key_file op(en:1 de:0)
int_file:加/解密源数据
out_file:结果数据
key_file:密钥
op 1加密、0解密
相关测试数据:
packages/example/security_utils/test_data/aes_test/
├── aes_test_data.txt ├── aes_test_en.txt └── key.txt
key.txt:key数据
aes_test_en.txt:该数据为结果数据
aes_test_data.txt:该数据为待测试数据
使用示例:
# aes_test aes_test_data.txt encrypt.txt key.txt 1 # aes_test encrypt.txt decrypt.txt key.txt 0 # cat aes_text_data.txt 123456789011111 # cat decrypt.txt 123456789011111
