DTRNG模块驱动接口
真随机数发生器,用于在加解密场景提供真随机数的功能。
module_drivers/drivers/char/hw_random/ingenic-rng.c
kernel内核dts文件路径:
DTRNG控制器描述:
dtrng: dtrng@0x10072000 {
 compatible = "ingenic,dtrng";
 reg = <0x10072000 0x100>;
 interrupts = <IRQ_DTRNG>;
 status = "disabled";
默认编译会产生dtrng设备。
&dtrng {
如果客户需要关闭dtrng设备,可以将以上节点配置为disabled。
&dtrng {
内核配置HW_RANDOM_INGENIC,配置说明如下:
Symbol: HW_RANDOM_INGENIC [=y]
Type : tristate
Prompt: Ingenic HW Random Number Generator support
 -> Device Drivers
 -> Character devices
(1) -> Hardware Random Number Generator Core support (HW_RANDOM [=y])
Prompt: [RANDOM] Ingenic HW Random Number Generator support
(2) -> [RANDOM] drivers
 Defined at drivers/char/hw_random/Kconfig:384
 Depends on: HW_RANDOM [=y] && MIPS [=y]
内核默认配置dtrng驱动,配置界面如下:
【图 1|内核默认编译配置|上传 img_01.png 后删掉本行】
客户可以根据实际情况,去掉该驱动的配置。
当驱动加载成功后,会生成/dev/hwrng, 用户可以根据此节点判断驱动是否成功加载。
可以通过以下应用程序,测试随机数。
#include<stdio.h>
#include<stdlib.h>
#include<linux/watchdog.h>
#include<sys/ioctl.h>
#include<sys/types.h>
#include<fcntl.h>
#include<unistd.h>
#include<errno.h>
int main(int argc, char *argv[])
        int fd ,retval;
        char buf[64] = {0};
        int cmd = 0;
        if (!argv[1])
                printf("argv[1] is NULL \n");
                exit(errno);
        fd = open(argv[1],O_RDONLY);
        if(fd < 0)
                printf("open %s false\n",argv[1]);
                exit(errno);
        if(read(fd,buf,32) < 0)
                printf(" read false\n");
        else
                printf("random_num register value %d\n",*(unsigned int *)buf);
        close(fd);
        return retval;
测试结果
# ./hwrng /dev/hwrng
random_num register value 9363246
random_num register value 1329736129
random_num register value 567871915
random_num register value 966768232
