NEMC外部存储控制器接口
是对片外存储器空间进行划分,输出符合各类静态存储器和总线接口规格的控制信号。可以使静态存储器(如NOR flash等设备)连接到该处理器。
内核驱动代码位置:
module_drivers/drivers/char/ingenic_nemc.c
module_drivers/dts-stage/x1600/x1600dtsi
nemc模块设备树:
nemc: nemc@0x13410000{
 compatible = "ingenic,x1600-nemc";
 reg = <0x13410000 0x1000>;
 status = "disable";
 ranges = <1 0 0x1b000000 0x1000000
 2 0 0x1a000000 0x1000000>;
 nand: nand@1{
 compatible = "ingenic,x1600-sfc";
 reg =<1 0 0x1000000>;
 ingenic,nemc-bus-width = <16>;
 ingenic,nemc-tCH = <10>;
 ingenic,nemc-tAW = <5>;
 ingenic,nemc-tBP = <10>;
 ingenic,nemc-tRAS = <15>;
 ingenic,nemc-tSTRV = <100>;
默认编译不会产生nemc设备
用户可根据需求在板级设备树中添加nemc,并使能
&nemc {
 status = "disable";
 pinctrl-names = "default";
 pinctrl-0 =<&nemc_pa>, <&nemc_pb>;
Symbol: INGENIC_NEMC [=n]
Type : boolean
Prompt: [NEMC] Ingenic Nemc Driver
 Defined at module_drivers/drivers/char/Kconfig
NEMC配置界面如下:
模块内核差异
无
设备加载成功后会在/dev目录下生成如下节点:
\# ls /dev/nemc
/dev/nemc
注意事项:目前nemc驱动只模拟出nemc timing 时序,具体读写需根据外存设备时序进行。驱动也应进行相对应的改动。
